Program Button
I’ve noticed if we hold the program button for a little while, the lights seem to do weird things. For example, one light moves up and down the row, followed by some other things.
This is a “backdoor” to putting the RC in a diagnostic state, holding the programming button down for about 15 sec. This is used to do functional testing here at our facility. A reset should restore the RC; it is just running a different section of code in the master. This is the reason that we when to version 10. It was possible for the RC to go into this state while you were on the field from noise on the program port if you are using version 9. This can not happen with version 10 code, unless you use the “backdoor”.
