there are about ten cubes on the field that the robot must “see” and assemble in the correct order cubs. For example, he passes the first circle and collects the second and third cubes and throws them to the base, drives the second circle and collects the fourth and first cubes and throws them to the base.
Dude explain!!
(if you want help)
OP has created at least a couple of other threads on this same question. Others have asked for more clarifying questions as well so they can understand and help. Can we get moderators to merge some of these threads?
Agreed. The person is based in Russia so the post is a little fishy.
problem in the enumerater
sorry i didn’t understand you
