I am new to Vex and new to RobotC and I’ve created this program:
#pragma config(Sensor, dgtl1, touch, sensorTouch)
#pragma config(Sensor, dgtl3, sonar, sensorSONAR_cm)
#pragma config(Sensor, dgtl9, encoderLeft, sensorQuadEncoder)
#pragma config(Sensor, dgtl11, encoderRight, sensorQuadEncoder)
#pragma config(Motor, port1, right, tmotorVex393_HBridge, openLoop)
#pragma config(Motor, port8, claw, tmotorVex393_MC29, openLoop)
#pragma config(Motor, port9, arm, tmotorVex393_MC29, openLoop)
#pragma config(Motor, port10, left, tmotorVex393_HBridge, openLoop, reversed)
//Functions for driver control
void driveControl() {
motor[left] = vexRT[Ch3]; //left motor to ch 3
motor[right] = vexRT[Ch2]; //right motor to ch 2
void armControl() {
if (vexRT[Btn5U] == 1) {
motor [arm] = 100;
if (vexRT[Btn5D] ==1) {
motor[arm] = -100;
if (vexRT[Btn5U] == 0 && vexRT[Btn5D] == 0) {
motor[arm] = 0;
void clawControl () {
if (vexRT [Btn6U] ==1) {
motor[claw] = 100;
if (vexRT[Btn6D] ==1) {
motor[claw] = -100;
if (vexRT[Btn6U] == 0 && vexRT[Btn6D] == 0) {
motor[claw] = 0;
task main()
while(true) {
driveControl();
armControl();
clawControl();
Trying to get the original Clawbot to work again. I’ve programmed it the way I believe is correct but when I plug in all the wires after building the Clawbot, it doesn’t work. Nothing happens. I’ve tried updating the firmware for all the cortexes, the vexnet keys, the remotes - nothing happens. What am I doing wrong?
Thank you!
