Programming a brake
How do I program a brake in a motor to hold on to an object? We use RobotC.
Thank you!
There is no specific way to program “brake” on the motors for the VEX EDR system. To hold an object, I suggest you send a small motor value of about 25 or lower. If for example you are using a claw, when the button is pressed to close it, send full power for perhaps 2 seconds and then switch to lower power to gold objects.
