Hi! I can’t get the arms to work using buttons. It’s not a motor problem because I tried it on a different port and the arms work then (Ch1 & 2). But using buttons it won’t work. I also tried the claw and the same thing happened - it works in port 2 using channels 1 & 2 on the joystick. But when I use buttons on the joystick it won’t work. It won’t let me attach a file. I pasted a copy of the button programming. Can you give me any suggestions?
if (vexRT[Btn5U]==1)
motor[LeftArm]=127;
else if (vexRT[Btn5D]==1)
motor[LeftArm]=-127;
else
motor[LeftArm]=0;
if (vexRT[Btn6U]==1)
motor[RightArm]=127;
else if (vexRT[Btn6D]==1)
motor[RightArm]=-127;
else
motor[RightArm]=0;
