Do I need the Programming Kit and the Starter Kit at the beginning?
No, you do not need the Vex Programming Kit to get you started. The Vex Micro-Controller or “brains of the unit” comes with a default program, so no programming is required. Programming is a new area that you will want to master later so that you can program your robot to do exactly what you want. The Programming Kit is not Mac compatible.**
