Not a Problem…
Maybe I missed it, but when using an Example Number, say, “For Example, a DEADBAND of 20 is used in certain cases.” or “Your DEADBAND value is dependent upon you Gear Ratio, I used 20 for this Example”.
I expect that this forum will be around for a long time, so having Complete and Accurate information contained in a Thread is a high priority of mine, besides, Mecanum Wheels are my Interest, Right Now… ![]()
**As an Aside, but Directly related to this: **
Think about when you were searching for answer to some question on the Internet… How many times do you find just a piece of the problem, that then leads you to other pieces, that occasionally leads you to the Whole Solution?? Do you sometimes wish, one of those first 5 Threads, had the Complete Solution, especially when a Deadline in looming, and you have been up for 18 Hours, and the Dew or Rock-Star is running Low??
For an Example, yesterday I was searching for Information on the CSF/LFD Firewall installed on a Debian 6.0.3 system.
Because, I was doing some reconfiguration on the Server, and it *appeared *that I killed the Web Server, which did not make any sense after rebooting and saw everything running… Then is occurred to me, that maybe the Firewall was messed up, disabling it “fixed the problem”. But leaving the Firewall down is not the answer for a Web Server, so into the CSF/LFD documentation I went… Most Documentation is Pretty Bad, so the first 25 or so links of Uses Help, which I expected to be the Most Helpful were not very helpful at all… Strangely Enough, the actual Documentation was the exact help I needed, much to my Surprise… :eek:
It turns out, if you have Multiple Failed SSH Logins to your Server, your IP Address get written to the csf.deny file, and ALL your Interactions with that Server, from your IP Address are blocked, HTTP, FTP, SSH, etc… After clearing my IP address from the csf.deny file, it all worked again… WOW, Bullet Dodged!!
You might not realize it, but the Vex Forum is Publicly Readable, and ALL your Posts are visible On the 'Net. Your words are bound to become part of someone’s Search Query Results. Imagine your “Good Karma” quantity increasing because of your Complete and Accurate posts… ( If you believe in Karma, or that someone is keeping track of things in The Big Picture… )
As an Aside/Aside, a Google Search of “Vex Forum marko easyc” netted about 50 Links, including this page, that I have never seen before on the Vex Forum, Show Groups.
So, to Recap, Your Words are Forever on the Internet, and if you Lead someone to right destination, that someone, or someone else is going to remember…
Try to Leave the World a Better Place than you found it… ![]()
( P.S. I see you were checking out the RoboShop Rover… That’s OK, I won’t tell your Vex Robot…
