Programming Opcontrol
You can use gyro sensor to improve driving and implement a deadzone using an array.
You can try resetting the gyro automatically if that happens. Or at least I think you can do that
Thanks a lot for showing me that forum, i will for sure take a look and try to understand it
For the equation you sent, does that work for left and right joysticks because we use tank control ?
and also if you have experiance in PROS would it look like this
left_drive_set((powf(controller.get_analog(pros::E_CONTROLLER_ANALOG_LEFT_Y),3))/ powf(127,2));
void left_drive_set (int speed)
  drive_left.move(speed);
  drive_left_b.move(speed);
Yes, it will work with both of the joysticks, so you can use it with tank control. I took a very similar approach to the way you have shown, so it should work.
ok then thanks a lot
