I have a question; how you increase the speed of the robot in VEXcode pro? I am new to VEXcode pro and C++.
What are you trying to accomplish? Are you trying to increase the speed of one motor or multiple motors at the same time with code?
Use the VEXCode Pro API:
Motor methods
Motor group methods
Drivetrain methods
Look for methods that set the velocity/RPM of the object.
I am trying to increase the speed of a 6 motor drivetrain
Use the set velocity function
Examples:
Motor1.setvelocity (500, rpm)
Or if you are using a drivetrain group use
Drivetrain.setvelocity (500, rpm)
If we are talking about the motors that make up the drivetrain:
motor.spin(12.0, voltageUnits::volt);
Voltage is from -12.0 to 12.0, with 0 being stopped.
The example code given is wrong. It should be
motor.spin(forward, 12.0, voltageUnits::volt);
According to the documentation found here
You are correct. Thank you for correcting my error. I initially thought the function was overloaded to accomodate not having that, but it appears that’s not the case. I looked at my example code in one of my vexcode libraries and you are correct that my code above is wrong:
vex::motor::spin(volts, voltageUnits::volt);
However your code is right:
vex::motor::spin(forward, volts, voltageUnits::volt);
Also the following works too
vex::motor::spin(fwd, volts, voltageUnits::volt);
