This is for BEST Hub… We are using step motors… (Until last night I thought there were called servos) The little black motors… As of right now I can only get the thing to turn like 90 degrees and not a full rotation. I am using Easy C program to run the robot… I was told you can make these step motors go all the way around… Can someone please help me.
Sorry about the delay, the motor is a servo motor and you should be able to move it about 180 degrees unless it is damaged. Try using the online window to verify it’s operation. Your kit should have more then one and confirm the behavior between the two. Also, make sure you have the newest version of easyC installed.
Adam
