Hello!
We’re having a bit of trouble programming because it’s our first time doing this competition and we are new to programming. We would like to know what to write in between the 2 “voids” when we put in the command for “pressed”. On the VCS Command Reference, it says to add a function, but we don’t know what a function is
You would need to set up a function and then call it. However, that may not be what you are looking for. If you want a simple control for say, moving a motor when a button is pressed, use something like this:
int main(){
if(Controller1.whateverbutton.pressing()){
motor.spin(directionType::fwd, 100, vex::velocityUnits::pct);
else{
motor.stop(brakeType::coast);
If you wanted to actually have a function go until completion, then you need to set it up beforehand. For example:
void shoot(){
task::sleep(1000);
// intakes ball
shooter.spin(directionType::fwd, 100, vex::velocityUnits::pct);
task::sleep(500);
shooter.stop(brakeType::coast);
// shoots ball
int main(){
Controller1.pressed(shoot);
To clarify, what you refer to as “a void” is, in fact, known generally as a function.
The syntax for a function in C-like languages (VCS uses C++) is something like this:
return_type function_name(arguments) {
// function body
The
void
keyword is a special return type that means a function doesn’t return any value.
With that in mind, see @jack202020 's answer
Little update: it worked! I tweeked it a little bit according to what our team needed and it works. Thank you again @jack202020 and @hotel
