Programming using other software
Hey guys,
I’m wondering if there’s any compilers out there for the cortex. I usually program in Eclipse and I would prefer that environment for programming rather than EasyC or RobotC.
Thanks!
try PROS. It’s what I’m currently using.
https://vexforum.com/t/purdue-robotics-os-pros-now-available/24257/1
or if your confidant in your ability to do so try ConVEX, but it’s for more advanced users.
[https://vexforum.com/t/convex-open-source-firmware-for-the-cortex/24284/1
oh and BTW, both of these are free :D](https://vexforum.com/t/convex-open-source-firmware-for-the-cortex/24284/1)
Yep, +1 to both PROS and Convex. Both are great
They are pretty much the only other options.
Awesome! I’ll take a look at that soon. Thanks for your help guys!
I would definitely recommend PROS considering it implements eclipse. Excellent product!
From another thread.
I used PROS last year and being able to code in normal C and eclipse was definitely a great plus, but it does have some disadvantages as well. A notable one is debugging, RobotC lets you see global variables and sensor values in a dock which makes debugging very easy. PROS lets you print statements to a console which works but is comparatively slow and cumbersome. ConVEX has Apollo for real time sensor and motor values, but having never used it I can’t comment on it.
I’ve tried PROS and I like it so far. I’ll also give conVEX a try tomorrow when I get close to a robot :stuck_out_tongue:
Just add it to the PROS environment. They are similar but the ConVEX library is open source.
I added it to PROs and will try to program something soon
