Proposing Rule Changes
One thing I would change is the rule of how illegal matchloads are 2 points. I think that this rule doesn’t make sense, because like in the pikes peak sig finals, the team that was losing just illegaly match loaded lots of triballs and won that match. Also how it doesn’t carry over finals matches.
10 motors w/o pneumatics, 8 with.
are you saying you want less pneumatics? could you elaborate a little.
i believe @turbodog is saying (correct me if i’m wrong) to create two different rules, one for those using pneumatics on their bot and one for those who aren’t.
i.e., you could stick with the current 8 motor limit and use pneumatics, or use 10 motors but no pneumatics.
110w motor limit, each tank is worth 11w OR 132w motor limit, each tank is worth 22w.
similar to what rule was a few years ago…
used to be 6 motors if running air, 8 without air
i think rule needs to come back, but with 10/8 instead
lot of teams can’t afford air… letting them run 10 motors would be a good tradeoff
Definitely useful, especially since our team just recently got pneumatics for worlds.
But you have to think about the teams from organizations with a ton of both, where all the teams will be using 8 motors and a crud ton of pneumatics.
that’s the current setup…
