Pros 3.2.0 Multitasking Broken
After updating to PROS 3.2.0 I noticed that all of my tasks are now broken. Does anyone know how to fix this? I uploaded an image of my code below with the error.
Captures
You need to specify the task arguments and task name as well. Take a look at the docs here: RTOS Facilities C++ API — PROS for V5 3.8.0 documentation
I noticed this too, you shouldn’t have to specify arguments that have defaults. It did work after I specified every parameter but it makes the code look less clean
I recommend you file an issue on the PROS GitHub if you haven’t already, if you want this to be fixed.
Unless the defaults cause ambiguity, as in this case. Look at the first and third constructors on the docs.
