JamsG
#1
Hello there,
I’m trying to install Pros for V5 on a linux machine
I’m following the instructions according to this page
https://pros.cs.purdue.edu/v5/getting-started/linux.html
To install the CLI, I used
python3.6 -m pip install --user https://github.com/purduesigbots/pros-cli/releases/download/3.1.4/pros_cli_v5-3.1.4-py3-none-any.whl
But I get the error message
AttributeError: module ‘serial’ has no attribute ‘Serial’
What have I done wrong?
hotel
#2
Looks like for some reason the pyserial module wasn’t installed correctly?
Try
python3.6 -m pip install pyserial
And see if that fixes it
JamsG
#3
after a lot of digging I found that the problem was I had another python module called “serial” that seemed to interfere pyserial
after uninstalling it via pip everything started to work fine
thank you though!
hotel
#4
Ah yeah that would do it.
Might be worth adding a note to the instructions about that- I seem to recall that happening to myself at some point a while ago
(Edit: that was mostly a note-to-self, but if someone wants to open a PR for that I won’t say no
