Pros bug? how to solve this warning
when is compile my file, it says:
ERROR - main:main - Extra data: line 527 column 2 (char 29123)
File “C:\hostedtoolcache\windows\Python\3.6.4\x64\lib\json_init_.py”, line 354, in loads
File “C:\hostedtoolcache\windows\Python\3.6.4\x64\lib\json\decoder.py”, line 342, in decode
json.decoder.JSONDecodeError: Extra data: line 527 column 2 (char 29123)
We detected something went wrong! Do you want to send a report? [y/N]:
How can i solve it? its really annoying but does not affect anything.
I’m getting a similar error.
Updating pros-mainline... ERROR - pros.cli.conductor:new_project - HTTPSConnectionPool(host='purduesigbots.github.io', port=443): Max retries exceeded with url: /pros-mainline/pros-mainline.json (Caused by SSLError(SSLError(185090184, '[X509] no certificate or crl found (_ssl.c:4053)')))
  File "/usr/share/python-wheels/requests-2.21.0-py2.py3-none-any.whl/requests/adapters.py", line 514, in send
    raise SSLError(e, request=request)
requests.exceptions.SSLError: HTTPSConnectionPool(host='purduesigbots.github.io', port=443): Max retries exceeded with url: /pros-mainline/pros-mainline.json (Caused by SSLError(SSLError(185090184, '[X509] no certificate or crl found (_ssl.c:4053)')))
What command did you run that results in this error? Or did you build using the button in the IDE?
Are you compiling the file or what?
I ran prosv5 conductor new-project example
I am unable to reproduce this. If you are able to come up with a minimum reproducible set of commands/steps, please file an issue and describe them at Issues · purduesigbots/pros · GitHub.
FYI, this is what I got:
[nmertin@HAL test]$ prosv5 conductor new-project example
Updating pros-mainline... Done
Applying [email protected] [####################################] 100%
Finished applying [email protected] to example
New PROS Project was created:
PROS Project for v5 at: /home/nmertin/test/example (example)
Name      Version    Origin
kernel    3.1.6      pros-mainline
okapilib  3.3.13     pros-mainline
Building project...
Compiling src/autonomous.cpp [OK]
Compiling src/initialize.cpp [OK]
Compiling src/opcontrol.cpp [OK]
Adding timestamp [OK]
Linking project with libpros,okapilib [ERRORS]
/usr/lib/gcc/arm-none-eabi/9.1.0/../../../../arm-none-eabi/bin/ld: /usr/lib/gcc/arm-none-eabi/9.1.0/../../../../arm-none-eabi/lib/libstdc++.a(locale.o): in function `std::locale::_Impl::_M_install_cache(std::locale::facet const*, unsigned int)':
locale.cc:(.text._ZNSt6locale5_Impl16_M_install_cacheEPKNS_5facetEj+0x18): undefined reference to `__sync_synchronize'
/usr/lib/gcc/arm-none-eabi/9.1.0/../../../../arm-none-eabi/bin/ld: /usr/lib/gcc/arm-none-eabi/9.1.0/../../../../arm-none-eabi/lib/libstdc++.a(locale_init.o): in function `(anonymous namespace)::get_locale_mutex()':
locale_init.cc:(.text._ZN12_GLOBAL__N_116get_locale_mutexEv+0xc): undefined reference to `__sync_synchronize'
/usr/lib/gcc/arm-none-eabi/9.1.0/../../../../arm-none-eabi/bin/ld: /usr/lib/gcc/arm-none-eabi/9.1.0/../../../../arm-none-eabi/lib/libstdc++.a(cxx11-ios_failure.o): in function `(anonymous namespace)::__io_category_instance()':
cxx11-ios_failure.cc:(.text._ZN12_GLOBAL__N_122__io_category_instanceEv+0xc): undefined reference to `__sync_synchronize'
collect2: error: ld returned 1 exit status
make: *** [common.mk:191: bin/monolith.elf] Error 1
The __sync_synchronize error is a separate, known issue and will be resolved soon.
Yes. That is typically what I get. However recently it broke. I have no idea why. I have python3 v3.7.3 prosv5 v3.1.4. I am running pop!_os v19.04.
The error is something with the pros-mainline with the httpsconnectionpool or ssl so it’s something with python. I don’t know the pros-mainline project enough to understand what could be going wrong so I wouldn’t know how to reproduce that error.
Are you on a school network? We tend to see that issue when access to GitHub is blocked.
This issue looks like you’ve got some extra, unparsable data sitting in your project.pros file. Check the line and column number mentioned in the error output.
alright. thanks for your help hotel
Did we figure it out? I’m having the same issue:
-e \x1b[31;01m[ERRORS]\x1b[0m
/usr/local/Cellar/arm-gcc-bin/8-2019-q3-update/bin/…/lib/gcc/arm-none-eabi/8.3.1/…/…/…/…/arm-none-eabi/bin/ld: /usr/local/Cellar/arm-gcc-bin/8-2019-q3-update/bin/…/lib/gcc/arm-none-eabi/8.3.1/…/…/…/…/arm-none-eabi/lib/libstdc++.a(cxx11-ios_failure.o): in function `(anonymous namespace)::__io_category_instance()':
cxx11-ios_failure.cc:(.text._ZN12_GLOBAL__N_122__io_category_instanceEv+0xc): undefined reference to `__sync_synchronize’
/usr/local/Cellar/arm-gcc-bin/8-2019-q3-update/bin/…/lib/gcc/arm-none-eabi/8.3.1/…/…/…/…/arm-none-eabi/bin/ld: /usr/local/Cellar/arm-gcc-bin/8-2019-q3-update/bin/…/lib/gcc/arm-none-eabi/8.3.1/…/…/…/…/arm-none-eabi/lib/libstdc++.a(locale.o): in function `std::locale::_Impl::_M_install_cache(std::locale::facet const*, unsigned int)':
locale.cc:(.text._ZNSt6locale5_Impl16_M_install_cacheEPKNS_5facetEj+0x18): undefined reference to `__sync_synchronize’
/usr/local/Cellar/arm-gcc-bin/8-2019-q3-update/bin/…/lib/gcc/arm-none-eabi/8.3.1/…/…/…/…/arm-none-eabi/bin/ld: /usr/local/Cellar/arm-gcc-bin/8-2019-q3-update/bin/…/lib/gcc/arm-none-eabi/8.3.1/…/…/…/…/arm-none-eabi/lib/libstdc++.a(locale_init.o): in function `(anonymous namespace)::get_locale_mutex()':
locale_init.cc:(.text._ZN12_GLOBAL__N_116get_locale_mutexEv+0xc): undefined reference to `__sync_synchronize’
make: *** [bin/monolith.elf] Error 1
Error: Failed to build
And I’m seeing people cite “stubbing” as a work-around:
void __sync_synchronize (void)
__sync_synchronize ();
But where do we cut and paste this code?
Just place
In any C file in your project.
For example, you could place it in a fine named src/stub.c.
I still get the same error.
you’ll need to also delete the contents of your bin directory, then rebuild. Alternatively, you could upgrade your project to version 3.2.0, which no longer has this issue:
