PROS Building Error
Hello All,
When we try to build our PROS code, it throws us the following error. Any Ideas on what might cause this?
38%20PM
Thanks
Abhinav
You need to install the arm toolchain. Instructions for linux are here:
https://pros.cs.purdue.edu/v5/getting-started/linux.html
Do note that the latest versions of the toolchain have issues with hot/cold linking, so you’ll probably want to install an older version.
Looks like you’re running on macOS… there’s actually some weird stuff going on atm with the arm developer site not properly providing the toolchain.
There’s a couple workarounds, one of which would be to use this homebrew tap/formula instead:
Another would be to follow the manual install instructions for macOS on our site.
Update: everything should be back to normal now
Thank you (20 Characters )
