PROS cannot detect V5 Brain
Hello guys. It seems like PROS isn’t detecting my V5 brain at the moment. I am using pros V5 on Linux Debian. I am not using pros editor, instead, I am using pros V5 command line in terminal. When I use the command “prosv5 -lsusb”, it says nothing is connected. However, on the brain, it says USB is connected.
Below is what’s shown in the terminal
qq1393018858@penguin:~ uname -a Linux penguin 4.19.86-07780-g3c6544b539b7 #1 SMP PREEMPT Tue Dec 3 20:51:44 PST 2019 x86_64 GNU/Linux qq1393018858@penguin:~ prosv5 --version
pros, version 3.1.4
qq1393018858@penguin:~$ gcc --version
gcc (Debian 6.3.0-18+deb9u1) 6.3.0 20170516
Copyright © 2016 Free Software Foundation, Inc.
This is free software; see the source for copying conditions. There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
qq1393018858@penguin:~$ arm-none-eabi-gcc --version
arm-none-eabi-gcc (GNU Tools for Arm Embedded Processors 9-2019-q4-major) 9.2.1 20191025 (release) [ARM/arm-9-branch revision 277599]
Copyright © 2019 Free Software Foundation, Inc.
qq1393018858@penguin:~ prosv5 lsusb There are no connected VEX EDR V5 System Ports There are no connected VEX EDR V5 User ports There are no connected VEX EDR Cortex Microcontroller Ports qq1393018858@penguin:~ sudo lsusb
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
I believe RMS (or possibly vexcode text) works on linux. Can you give one of those a shot to see if they detect the brain? If not, it’s likely something on your end, like a bad cable or port, and not something we have control over.
