PROS CLI 3.2.1 Release - Bugfixes for 3.2.0
This update should fix many of the issues introduced in the last release. Wireless uploading/terminal is now functioning normally. Windows Installers have also been remade and should not have any environment variable issues.
Upgrading
Windows
Download and run the appropriate installer. ( pros-windows-3.2.1.0-64bit.exe )
Notes
  • You may be stopped by Windows SmartScreen when running the installer. This is expected, and we are working to resolve this issue. In the meantime, click “more info” and “run anyway” (if your system is set to block unknown apps and programs, you’ll have to change the SmartScreen settings to “warn” or disable checking entirely [which we don’t recommend]).
  • If you applied the workaround detailed in the release notes for 3.2.0 (adding an entry to the PATH environment variable), you can go ahead and remove it if you wish.
MacOS
Run brew update && brew upgrade pros-cli
Linux / pip installs
Run pip install --upgrade pros-cli
For upgrade instructions and more information, check out our blog post here.
Notes for Windows users
  • we’ve received some reports that the CLI can’t be found on PATH after the install. In most cases, this is solved by restarting your computer.
We tried updating PROS and the wireless upload still doesn’t work for us.
What does this mean?
Instead of using the solution tool, hotel has “reserved” that post spot for editing. It’s a common practice in many other forums however it doesn’t really work if you can not edit a post past a certain time limit.
Yeah, lol. There’s a 24hr time limit on edits here.
What did you update? What steps did you take?
Pretty sure he was reserving a hotel room
You are a funny man.
We updated to the new version but we didn’t uninstall the old version.
