PROS Display Daemon Error
I’m using EZ Template’s autonomous selector, and while the screen loads correctly, when I press the left or right buttons the following error message shows:
DATA ABORT EXCEPTION
PC: 381d8d0
CURRENT TASK: Display Daemon (PROS)
Can anyone tell me what is going on and how to fix this?
You’ll need to share your code for us to help you at all.
#include "main.h"
/* Documentation */
// https://ez-robotics.github.io/EZ-Template/
// Chassis constructor, edit accordingly
ez::Drive chassis(
    // These are your drive motors, the first motor is used for sensing!
    {-1, -2, 8},  // Left Chassis Ports, (use negative numbers for reversed motors!)
    {4, 5, -6},  // Right Chassis Ports (use negative numbers for reversed motors!)
    7,          // IMU (inertial) port
    3.25,      // Wheel Diameter (Remember, 4" wheels without screw holes are actually 4.125!)
    360         // Wheel RPM
 * Runs initialization code. This occurs as soon as the program is started.
 * All other competition modes are blocked by initialize; it is recommended
 * to keep execution time for this mode under a few seconds.
void initialize()
  ez::ez_template_print();
  pros::delay(500);  // Stop the user from doing anything while legacy ports configure
  // Configure your chassis controls
  // Enables modifying the controller curve with buttons on the joysticks
  chassis.opcontrol_curve_buttons_toggle(true);
  // Sets the active brake kP. We recommend ~2.  0 will disable.
  chassis.opcontrol_drive_activebrake_set(2);
  // Defaults for curve. If using tank, only the first parameter is used.
  // (Comment this line out if you have an SD card!)
  chassis.opcontrol_curve_default_set(0, 0);
  // Set the constants using the function defined in autons.cpp
  default_constants();
  // Autonomous Selector
  ez::as::auton_selector.autons_add(
    Auton("Draw Right-Handed Square\nPLEASE DONT ACTUALLY RUN THIS DURING COMPETITION", draw_square),
    Auton("RED Left Side\n\nSetup on 3rd from left\n\nBack lined up with inner forward edge\n\nWall riders lined up with inner left edge", red_left),
    Auton("RED Right Side\n\nSetup on 2nd from right\n\nBack lined up with inner forward edge\n\nWall riders lined up with inner left edge", red_right),
    Auton("BLUE Right Side\n\nSetup on 3nd from right\n\nBack lined up with inner forward edge\n\nWall riders lined up with inner right edge", blue_right),
    Auton("RED Right Side\n\nSetup on 2nd from left\n\nBack lined up with inner forward edge\n\nWall riders lined up with inner right edge", blue_left)
  // Initialize chassis and auton selector
  chassis.initialize();
  ez::as::initialize();
  master.rumble(".");
 * Runs while the robot is in the disabled state of Field Management System or
 * the VEX Competition Switch, following either autonomous or opcontrol. When
 * the robot is enabled, this task will exit.
void disabled()
  // Add your code here
 * Runs after initialize(), and before autonomous when connected to the Field
 * Management System or the VEX Competition Switch. This is intended for
 * competition-specific initialization routines, such as an autonomous selector
 * on the LCD.
 * This task will exit when the robot is enabled and autonomous or opcontrol
 * starts.
void competition_initialize()
 * Runs the user autonomous code. This function will be started in its own task
 * with the default priority and stack size whenever the robot is enabled via
 * the Field Management System or the VEX Competition Switch in the autonomous
 * mode. Alternatively, this function may be called in initialize or opcontrol
 * for non-competition testing purposes.
 * If the robot is disabled or communications is lost, the autonomous task
 * will be stopped. Re-enabling the robot will restart the task, not re-start it
 * from where it left off.
void autonomous()
  chassis.pid_targets_reset();                // Resets PID targets to 0
  chassis.drive_imu_reset();                  // Reset gyro position to 0
  chassis.drive_sensor_reset();               // Reset drive sensors to 0
  chassis.drive_brake_set(MOTOR_BRAKE_HOLD);  // Set motors to hold. This helps autonomous consistency
  // Calls selected auton from autonomous selector
  ez::as::auton_selector.selected_auton_call();
 * Runs the operator control code. This function will be started in its own task
 * the Field Management System or the VEX Competition Switch in the operator
 * control mode.
 * If no competition control is connected, this function will run immediately
 * following initialize().
 * operator control task will be stopped. Re-enabling the robot will restart the
 * task, not resume it from where it left off.
void neutralscore(){
  chassis.drive_angle_set(0);
  while(FrontDistance.get()>230){
    chassis.pid_drive_set(3,70);
    chassis.pid_wait_quick();
    pros::delay(300);
void alliancescore(){
    pros::delay(300);
void opcontrol()
  // This is preference to what you like to drive on
  // MOTOR_BRAKE_HOLD (recommended), MOTOR_BRAKE_BRAKE, MOTOR_BRAKE_COAST
  pros::motor_brake_mode_e_t driver_preference_brake = MOTOR_BRAKE_COAST;
  // chassis.opcontrol_tank();  //  Tank control
  chassis.opcontrol_arcade_standard(ez::SPLIT);   // Standard split arcade USE THIS
  // chassis.opcontrol_arcade_standard(ez::SINGLE);  // Standard single arcade
  // chassis.opcontrol_arcade_flipped(ez::SPLIT);    // Flipped split arcade
  // chassis.opcontrol_arcade_flipped(ez::SINGLE);   // Flipped single arcade
  chassis.drive_brake_set(driver_preference_brake);
  bool clampstate=0;
  Clamp.set_value(false);
  bool lifterstate;
  Lifter.set_value(false);
  Arm1.move_velocity(0);
  Arm2.move_velocity(0);
  Arm1.set_brake_mode(MOTOR_BRAKE_HOLD);
  Arm2.set_brake_mode(MOTOR_BRAKE_HOLD);
  Arm1.tare_position();
  Arm2.tare_position();
  Arm1.set_encoder_units(MOTOR_ENCODER_DEGREES);
  Arm2.set_encoder_units(MOTOR_ENCODER_DEGREES);
  int armstate = 0;
  int armtarget = 1;
  // 1 = neutral stake
  // 0 = alliance stake
  while (true)
    // Intake Control
    if (master.get_digital(pros::E_CONTROLLER_DIGITAL_R1)){
      Intake.move_velocity(200);
    else if (master.get_digital(pros::E_CONTROLLER_DIGITAL_R2)){
      Intake.move_velocity(-200);
    else{
      Intake.move_velocity(0);
    // Arm Auto Control
    if (master.get_digital_new_press(pros::E_CONTROLLER_DIGITAL_L2)){
      if (armstate==1){
        armstate=-1;
      else if(armstate=-1){
        armstate=1;
    if (armstate==1){
      if (armtarget==0){
        if (Arm1.get_position()>=470){
        else{
          Arm1.move_velocity(200);
          Arm2.move_velocity(-200);
      else{
        if (Arm1.get_position()>=670){
        else{
    if (armstate==-1){
      if (Arm1.get_position()<=0){
      else{
        Arm1.move_velocity(-100);
        Arm2.move_velocity(100);
    // Clamp Control
    if (master.get_digital_new_press(pros::E_CONTROLLER_DIGITAL_L1)){
      if (clampstate==1){
        clampstate=0;
      else{
        clampstate=1;
      Clamp.set_value(clampstate);
    // Arm Maunual Mode Control
    if (master.get_digital_new_press(pros::E_CONTROLLER_DIGITAL_UP)){
      if (armtarget==1){
        armtarget=0;
      else{
        armtarget=1;
    // Arm Align Automatic Control
    if (master.get_digital_new_press(pros::E_CONTROLLER_DIGITAL_DOWN)){
      if (armtarget==1){
        neutralscore();
      else{
        alliancescore();
    // Lifter Control
    if (master.get_digital_new_press(pros::E_CONTROLLER_DIGITAL_X)){
      if (lifterstate==1){
        lifterstate=0;
      else{
        lifterstate=1;
      Lifter.set_value(lifterstate);
    //TESTING ONLY
    if (master.get_digital(DIGITAL_B) && master.get_digital(DIGITAL_DOWN)){
      autonomous();
    // This is used for timer calculations!  Keep this ez::util::DELAY_TIME
    pros::delay(ez::util::DELAY_TIME);
Main file ^^^
#include "main.h"
/* Documentation */
 * Sets the speed you drive, turn, and swing at
 * during autonomous. Values range from 0-127.
 * I suggest against going above 100, as it will
 * burn out your motors very quickly.
const int DRIVE_SPEED = 90;
const int TURN_SPEED = 90;
const int SWING_SPEED = 90;
// PID Constants
// Adjust accordingly, read documentation for more information
void default_constants() {
  chassis.pid_heading_constants_set(5, 0, 20);
  chassis.pid_drive_constants_set(20, 0, 100);
  chassis.pid_turn_constants_set(3, 0.05, 20, 15);
  chassis.pid_swing_constants_set(6, 0, 65);
  chassis.pid_turn_exit_condition_set(80_ms, 3_deg, 250_ms, 7_deg, 500_ms, 500_ms);
  chassis.pid_swing_exit_condition_set(80_ms, 3_deg, 250_ms, 7_deg, 500_ms, 500_ms);
  chassis.pid_drive_exit_condition_set(80_ms, 1_in, 250_ms, 3_in, 500_ms, 500_ms);
  chassis.pid_turn_chain_constant_set(3_deg);
  chassis.pid_swing_chain_constant_set(5_deg);
  chassis.pid_drive_chain_constant_set(3_in);
  chassis.slew_drive_constants_set(7_in, 80);
// WRITE ACTUAL FUNCTIONS HERE
// Add your autonomous functions here
void deploy(){
  bool clampstate=0;
  Lifter.set_value(1);
void draw_square(){
  for(int i=0;i<4;i++){
    chassis.pid_drive_set(24,100);
    chassis.pid_wait();
    chassis.pid_turn_relative_set(90,70);
    chassis.pid_wait();
void red_left(){
  chassis.pid_drive_set(-22,100);
  chassis.pid_wait();
  chassis.pid_turn_relative_set(-50,70);
  chassis.pid_wait();
  Clamp.set_value(0);
  chassis.pid_drive_set(-14,70);
  chassis.pid_wait();
  Clamp.set_value(1);
  chassis.pid_drive_set(26,100);
  chassis.pid_wait();
  Lifter.set_value(0);
  pros::delay(750);
  chassis.pid_drive_set(-5,100);
  chassis.pid_wait();
  chassis.pid_turn_set(-90,70);
  chassis.pid_wait();
  chassis.pid_drive_set(-40,100);
  chassis.pid_wait();
  chassis.pid_turn_relative_set(-100,70);
  chassis.pid_wait();
  chassis.pid_drive_set(27,100);
  chassis.pid_wait();
  pros::delay(250);
  chassis.pid_drive_set(-10,100);
  chassis.pid_wait();
void red_right(){
  chassis.pid_wait();
  chassis.pid_wait();
  Clamp.set_value(0);
  chassis.pid_wait();
  Clamp.set_value(1);
  chassis.pid_wait();
  chassis.pid_drive_set(20,100);
  chassis.pid_wait();
  pros::delay(500);
  chassis.pid_drive_set(-8,70);
  chassis.pid_wait();
  pros::delay(500);
void blue_right(){
  chassis.pid_wait();
  chassis.pid_turn_relative_set(50,70);
  chassis.pid_wait();
  Clamp.set_value(0);
  chassis.pid_wait();
  Clamp.set_value(1);
  chassis.pid_wait();
  pros::delay(750);
  chassis.pid_wait();
  chassis.pid_turn_set(90,70);
  chassis.pid_wait();
  chassis.pid_wait();
  chassis.pid_turn_relative_set(100,70);
  chassis.pid_wait();
  chassis.pid_wait();
  pros::delay(250);
  chassis.pid_wait();
void blue_left(){
  chassis.pid_wait();
  chassis.pid_wait();
  Clamp.set_value(0);
  chassis.pid_wait();
  Clamp.set_value(1);
  chassis.pid_wait();
  chassis.pid_wait();
  pros::delay(500);
  chassis.pid_wait();
  pros::delay(500);
Autonomous functions ^^^
Sorry for not including code in my original post, I was somewhat panicked and didn’t think before posting.
Never mind, figured it out. Turns out I had too much text and it didn’t fit onto the screen .-.
