I have been using Ez-Template for a while now and have had very little issues, but recently I noticed that no matter what I try it only runs the drive example. I have completely deleted the code in auton and it still does this, I know it’s downloading as it changes other aspects of the screen such as the auton name. Nut even if it wasn’t the other auton selections only run this code as well. I have already gotten and entire new example project and only inputted the motors and IMU Sensor. And I have tried a comp brain, switch, and all 3 ways from the controller to run it. In the end I’m not sure how to move forward, and have 6 days to complete this before Worlds. The only other thing I have noticed is that the PID variable seem to have no affect, and that it only drives forward then backwards which is different than what the Example drive says as it says you drive back in two steps. ANY help is appreciated as we really don’t know what to do.
Did you ever figure out what the issue was? I am having the same problem, whenever i go to run an auton no matter if i change my selection in driver control it always runs the same auton.
I’m having the same problem in a different way. I was able to add my auton but then a few days ago, It just wouldn’t let me update anything in the auton file.
