PROS Header File help
Im trying to create a header file to config motors and have them used in all files, im running into errors in the main.h file
main.h
     * \file main.h
     * Contains common definitions and header files used throughout your PROS
     * project.
     * Copyright (c) 2017-2018, Purdue University ACM SIGBots.
     * All rights reserved.
     * This Source Code Form is subject to the terms of the Mozilla Public
     * License, v. 2.0. If a copy of the MPL was not distributed with this
     * file, You can obtain one at http://mozilla.org/MPL/2.0/.
#ifndef _PROS_MAIN_H_
#define _PROS_MAIN_H_
 * If defined, some commonly used enums will have preprocessor macros which give
 * a shorter, more convenient naming pattern. If this isn't desired, simply
 * comment the following line out.
 * For instance, E_CONTROLLER_MASTER has a shorter name: CONTROLLER_MASTER.
 * E_CONTROLLER_MASTER is pedantically correct within the PROS styleguide, but
 * not convienent for most student programmers.
#define PROS_USE_SIMPLE_NAMES
 * If defined, C++ literals will be available for use. All literals are in the
 * pros::literals namespace.
 * For instance, you can do `4_mtr = 50` to set motor 4's target velocity to 50
#define PROS_USE_LITERALS
#include "api.h"
#include "config.hpp"
 * You should add more #includes here
//#include "okapi/api.hpp"
//#include "pros/api_legacy.h"
 * If you find doing pros::Motor() to be tedious and you'd prefer just to do
 * Motor, you can use the namespace with the following commented out line.
 * IMPORTANT: Only the okapi or pros namespace may be used, not both
 * concurrently! The okapi namespace will export all symbols inside the pros
 * namespace.
// using namespace pros;
// using namespace pros::literals;
// using namespace okapi;
 * Prototypes for the competition control tasks are redefined here to ensure
 * that they can be called from user code (i.e. calling autonomous from a
 * button press in opcontrol() for testing purposes).
#ifdef __cplusplus
extern "C" {
#endif
void autonomous(void);
void initialize(void);
void disabled(void);
void competition_initialize(void);
void opcontrol(void);
#ifdef __cplusplus
#endif
#ifdef __cplusplus
 * You can add C++-only headers here
//#include <iostream>
#endif
#endif  // _PROS_MAIN_H_
config.hpp
 #pragma once
#include "main.h"
extern pros::Motor LeftF;
extern  pros::Motor LeftB;
extern  pros::Motor RightF;
extern  pros::Motor RightB;
extern pros::Motor Intake;
extern pros::Motor Catapult;
extern pros::Motor Strafe;
extern pros::Controller master;
extern pros::ADILineSensor LineLeft;
extern pros::ADIGyro Gyro1;
extern pros::ADIPotentiometer catapultPT;
void initDriveTrain();
void initStrafe();
void initCatapult();
void initSensors();
config.cpp
#include "main.h"
void initDriveTrain(){
  pros::Motor LeftF(11, pros::E_MOTOR_GEARSET_18, false, pros::E_MOTOR_ENCODER_DEGREES);
  pros::Motor LeftB(15, pros::E_MOTOR_GEARSET_18, false, pros::E_MOTOR_ENCODER_DEGREES);
  pros::Motor RightF(13, pros::E_MOTOR_GEARSET_18, true, pros::E_MOTOR_ENCODER_DEGREES);
  pros::Motor RightB(5, pros::E_MOTOR_GEARSET_18, true, pros::E_MOTOR_ENCODER_DEGREES);
void initStrafe(){
  pros::Motor Strafe(11, pros::E_MOTOR_GEARSET_18, false, pros::E_MOTOR_ENCODER_DEGREES);
void initCatapult(){
  pros::Motor Catapult(10, pros::E_MOTOR_GEARSET_36, false, pros::E_MOTOR_ENCODER_DEGREES);
  pros::Motor Intake(1, pros::E_MOTOR_GEARSET_36, false, pros::E_MOTOR_ENCODER_DEGREES);
void initSensors(){
  pros::ADILineSensor LineLeft (4);
  pros::ADILineSensor LineRight (5);
  pros::ADIGyro Gyro1 (3);
  pros::ADIPotentiometer catapultPT(1);
errors:
Preformatted text
Your header only supports C++. You should add it to the section for C++ -only headers.
#ifdef __cplusplus
#endif
everything works and errors have gone!!! Thank you!
