PROS help
So I have 2 questions about PROS:
  1. So I have recently switched to PROS and wrote an auton selection program.
    I stored the selected auton in a variable (in “init.c”) but I don’t know how to access it from the “auto.c” file.
  2. Can someone please explain how to include a header file in PROS?
Take a look at this
The magic of PROS is that it is just C. You can google any c question and find a hundred answers all of which apply directly to PROS.
  1. There’s a couple ways to do this. The simplest way could be:
init.c:
int selectedAutonomous = 0;
void initialize() {
     selectedAutonomous = 4; // you put whatever logic you want to select the auton
auto.c
extern int selectedAutonomous;
void autonomous() {
    printf("Autonomous selected was %d\n", selectedAutonomous);
    switch(selectedAutonomous) {
          case 0:
               // do whatever 0
               break;
        case 1:
              // do whatever 1
              break;
        // etc.
  1. You can just write
#include "myHeader.h"
at the top of the file. Anything you write in myHeader.h will be copied into that file. Most header files look like:
#ifndef _MY_HEADER_H_
#define _MY_HEADER_H_
#include "anotherHeader.h"
void myFunction();
void myOtherFunction();
extern int myVariable;
#endif
As an alternative, what you could do instead of using
for every header file you want to use in each .c file, what you could do is put
#include
for every header file you use into your
main.h
file, and then in each of your source files use
#include "main.h"
. For example-
main.h:
#ifndef MAIN_H_
// This prevents multiple inclusion, which isn't bad for this file but is good practice
#define MAIN_H_
#include <API.h>
#include "library.h"
#include "motor.h"
#include "subsystems.h"
#include "opcontrolActions.h"
#include "autolibrary.h"
#include "PID.h"
#include "autonTasks.h"
#include "autonSkills.h"
// Allow usage of this file in C++ programs
#ifdef __cplusplus
extern "C" {
#endif
void autonomous();
void initializeIO();
void initialize();
void operatorControl();
// End C++ export structure
#ifdef __cplusplus
#endif
#endif
and in opcontrol.c:
#include "main.h"
void operatorControl(){
  while(1){
    opcontrolTankDrive();
    opcontrolMobileGoal();
    opcontrolLinearGear();
    opcontrolChainBar();
	opcontrolConeGrabber();
    opcontrolStack();
	opcontrolPanic();
    opcontrolDebug();
    delay(20);
