We’re happy to announce the release of PROS kernel 3.2.1!
For information on what’s changed and important upgrade notes, please read our blog post.
To upgrade your projects, either use the PROS > Upgrade Project menu in the PROS Editor or run prosv5 conduct upgrade kernel inside your project directory on the command line.
yes, using either of the two methods I mentioned in the OP. the editor GUI allows you to select the desired version for each template installed in your project, while the CLI method I noted will upgrade only the specified template (here kernel).
