Hey all,
I am new to PROS, and using lemlib and was following this youtube: https://www.youtube.com/watch?v=4DwnphVdJZY
but apprently my motor is not moving whilest other drive control being working all fine.
Here is my code for main.cpp
#include "main.h"
#include "lemlib/api.hpp" // IWYU pragma: keep
#include "pros/motors.hpp"
#define LF_PORT 1
#define LB_PORT 16
#define RF_PORT 10
#define RB_PORT 18
#define IU_PORT 13
#define ID_PORT 20
// controller
pros::Controller controller(pros::E_CONTROLLER_MASTER);
// motor groups
pros::MotorGroup leftMotors({-1, -16},pros::MotorGearset::blue); // left motor group - ports 3 (reversed), 4, 5 (reversed)
pros::MotorGroup rightMotors({10, 18}, pros::MotorGearset::blue); // right motor group - ports 6, 7, 9 (reversed)
// motors
pros::Motor IntakeU(13);
pros::Motor IntakeD(20);*/
// Inertial Sensor on port 10
pros::Imu imu(17);
// tracking wheels
// horizontal tracking wheel encoder. Rotation sensor, port 20, not reversed
pros::Rotation horizontalEnc(20);
// vertical tracking wheel encoder. Rotation sensor, port 11, reversed
pros::Rotation verticalEnc(-11);
// horizontal tracking wheel. 2.75" diameter, 5.75" offset, back of the robot (negative)
lemlib::TrackingWheel horizontal(&horizontalEnc, lemlib::Omniwheel::NEW_275, -5.75);
// vertical tracking wheel. 2.75" diameter, 2.5" offset, left of the robot (negative)
lemlib::TrackingWheel vertical(&verticalEnc, lemlib::Omniwheel::NEW_275, -2.5);
// drivetrain settings
lemlib::Drivetrain drivetrain(&leftMotors, // left motor group
&rightMotors, // right motor group
10, // 10 inch track width
lemlib::Omniwheel::NEW_4, // using new 4" omnis
360, // drivetrain rpm is 360
2 // horizontal drift is 2. If we had traction wheels, it would have been 8
// lateral motion controller
lemlib::ControllerSettings linearController(10, // proportional gain (kP)
0, // integral gain (kI)
3, // derivative gain (kD)
3, // anti windup
1, // small error range, in inches
100, // small error range timeout, in milliseconds
3, // large error range, in inches
500, // large error range timeout, in milliseconds
20 // maximum acceleration (slew)
// angular motion controller
lemlib::ControllerSettings angularController(2, // proportional gain (kP)
10, // derivative gain (kD)
3, // anti windup
1, // small error range, in degrees
3, // large error range, in degrees
// sensors for odometry
lemlib::OdomSensors sensors(nullptr, // vertical tracking wheel
nullptr, // vertical tracking wheel 2, set to nullptr as we don't have a second one
nullptr, // horizontal tracking wheel
nullptr, // horizontal tracking wheel 2, set to nullptr as we don't have a second one
&imu // inertial sensor
// input curve for throttle input during driver control
lemlib::ExpoDriveCurve throttleCurve(3, // joystick deadband out of 127
10, // minimum output where drivetrain will move out of 127
1.019 // expo curve gain
// input curve for steer input during driver control
lemlib::ExpoDriveCurve steerCurve(3, // joystick deadband out of 127
// create the chassis
lemlib::Chassis chassis(drivetrain, linearController, angularController, sensors, &throttleCurve, &steerCurve);
* Runs initialization code. This occurs as soon as the program is started.
* All other competition modes are blocked by initialize; it is recommended
* to keep execution time for this mode under a few seconds.
void initialize() {
pros::lcd::initialize(); // initialize brain screen
chassis.calibrate(); // calibrate sensors
// the default rate is 50. however, if you need to change the rate, you
// can do the following.
// lemlib::bufferedStdout().setRate(...);
// If you use bluetooth or a wired connection, you will want to have a rate of 10ms
// for more information on how the formatting for the loggers
// works, refer to the fmtlib docs
// thread to for brain screen and position logging
pros::Task screenTask([&]() {
while (true) {
// print robot location to the brain screen
pros::lcd::print(0, "X: %f", chassis.getPose().x); // x
pros::lcd::print(1, "Y: %f", chassis.getPose().y); // y
pros::lcd::print(2, "Theta: %f", chassis.getPose().theta); // heading
// log position telemetry
lemlib::telemetrySink()->info("Chassis pose: {}", chassis.getPose());
// delay to save resources
pros::delay(50);
* Runs while the robot is disabled
void disabled() {}
* runs after initialize if the robot is connected to field control
void competition_initialize() {}
// get a path used for pure pursuit
// this needs to be put outside a function
ASSET(example_txt); // '.' replaced with "_" to make c++ happy
* Runs during auto
* This is an example autonomous routine which demonstrates a lot of the features LemLib has to offer
void autonomous() {
// Move to x: 20 and y: 15, and face heading 90. Timeout set to 4000 ms
chassis.moveToPose(20, 15, 90, 4000);
// Move to x: 0 and y: 0 and face heading 270, going backwards. Timeout set to 4000ms
chassis.moveToPose(0, 0, 270, 4000, {.forwards = false});
// cancel the movement after it has traveled 10 inches
chassis.waitUntil(10);
chassis.cancelMotion();
// Turn to face the point x:45, y:-45. Timeout set to 1000
// dont turn faster than 60 (out of a maximum of 127)
chassis.turnToPoint(45, -45, 1000, {.maxSpeed = 60});
// Turn to face a direction of 90º. Timeout set to 1000
// will always be faster than 100 (out of a maximum of 127)
// also force it to turn clockwise, the long way around
chassis.turnToHeading(90, 1000, {.direction = AngularDirection::CW_CLOCKWISE, .minSpeed = 100});
// Follow the path in path.txt. Lookahead at 15, Timeout set to 4000
// following the path with the back of the robot (forwards = false)
// see line 116 to see how to define a path
chassis.follow(example_txt, 15, 4000, false);
// wait until the chassis has traveled 10 inches. Otherwise the code directly after
// the movement will run immediately
// Unless its another movement, in which case it will wait
pros::lcd::print(4, "Traveled 10 inches during pure pursuit!");
// wait until the movement is done
chassis.waitUntilDone();
pros::lcd::print(4, "pure pursuit finished!");
* Runs in driver control
void opcontrol() {
pros::Motor IntakeU(IU_PORT);
pros::Motor IntakeD(ID_PORT);
// controller
// loop to continuously update motors
while (true) {
// get joystick positions
int leftY = controller.get_analog(pros::E_CONTROLLER_ANALOG_LEFT_Y);
int rightX = controller.get_analog(pros::E_CONTROLLER_ANALOG_RIGHT_X);
// move the chassis with curvature drive
chassis.curvature(leftY, rightX);
IntakeU.move(120);
IntakeD.move(120);
pros::delay(2);
hope someone could provide me with help.
Thanks!
