So I just recently finished a program and now when I press the build button on the menu bar it doesn’t respond to my command. Did I do something wrong in my settings? It used to work and just stopped working recently.
Not sure what can be messed up in your PROS/Atom editor, but you can always resort to the command line, chdir into your project folder and issue “prosv5 mut” (make, upload, run terminal)
Forgot to mention the cmd also stopped appearing even after I tried to open it
You’re on windows, right?
What happens if you press Window+R, type cmd and Enter? You should still get the command prompt and that should allow you to “cd” where your project is and “prosv5 mut” to compile/run it…
Thanks, problem solved
