PROS on Linux
Anyone here using Pros on Linux? I’m running Archlinux and would really like to not have to use a Windows vm like I have been doing the past few years to run RobotC. I’m excited for the new release.
PROS is designed to work on Linux…
https://pros.cs.purdue.edu/cortex/getting-started/debian-linux.html
im trying to load pros-cli but i keep getting this error.
any idea?
BTW I use Arch linux.
I think PROS for Linux is for debian-based Linux distros.
That’s probably what’s causing an issue with the install.
Make sure you install all the packages listed here (except Atom if you will use some other IDE):
https://pros.cs.purdue.edu/cortex/getting-started/debian-linux.html#other-distro-installation-requirements
Specifically, check that you have the last 2 Python packages.
That’s a problem introduced in pip versions >=10. One temporary workaround is to downgrade pip for the install. We apologize for the inconvenience.
BINGO! We are in business. Thank you, i cant wait to see Version 3
