Pros problem with #include “main.h”
i’m just starting to use pros for my code and i’m using ez template to allow better autonomous functionality but every time I go to try and download I can’t due to a constant problem that won’t go away no matter what I do
Firstly, did you install a linter extension? Install clangd or microsoft C/C++.
Secondly, you have the wrong folder open. You need to open the project folder called EZ-Template-Example-Proj-2.2.0 that is inside another folder with the same name. You currently only have the outer folder open.
Finally, make sure the PROS extension is installed and working correctly by going to the sidebar and clicking Verify PROS Installation
