PROS Program File Error
I’ve been trying to upload to the v5 brain, but I keep getting the same error. I’ve included the full message. Here’s what I’ve tried:
  • restarting all devices
  • verifying latest software versions (firmware, CLI, etc)
  • cleaning project
  • changing program slots
  • swapping USB cable
  • updating kernel
I’m not sure what’s causing the problem, but nothing I’ve done seems to work. My code is working and compiling without any issues, and this is the first time I’ve seen this.
Depending on the port that I select, I also sometimes get this error:
It mentions that I should upgrade PROS, but it lists the latest CLI version, so I’m not sure what I should do with that information
Delete all programs on the V5 from the settings menu and try again. When I’ve seen that it’s something to do with the PROS hot/cold packages getting messed up somehow.
