while try to use remote control usb to load code, suddenly the port is no longer recognizable . got a message says: usb driver failed and it says usb device is malfunction.
tried to uninstall the driver. it did not really work.
If you are using a laptop, it is very common for some USB ports to freak out with the V5 system. Try plugging the USB cord into the USB port on the other side of the laptop, and tell me if it works. If not, I can think of other ways that could be the problem.
