From this release forward, we are providing our own distribution of Atom, called PROS Editor. PROS Editor has all the same features as Atom, but it sports a PROS logo as its icon, and comes preinstalled with the PROS package for Atom and its dependencies. If you are upgrading from a previous version of PROS, the PROS Editor will not be installed by default. The PROS Editor can also be installed and used alongside Atom, without making any changes to your existing Atom workspace. Note that we will continue to support the PROS plugin using regular Atom. You may still install Atom on your own and use the PROS plugin if you wish.
The installation process for MacOS has been greatly enhanced. Along with a shiny new installer, MacOS users no longer need to have Python 3 installed before using PROS.
Windows users are now able to properly install PROS on a per-user basis.
Debian/Ubuntu users can now use .deb packages for PROS and the PROS Editor.
Library Management
You can now share your code with others using PROS libraries!
Use GitHub Releases or your own custom providers to distribute your libraries.
Edit: apparently my post was too long the forum does not like unicode
Known Issues:
MacOS
/Applications/PROS CLI.app
may have a “cancel” sign over the icon if your OS version is less than 10.13. Don’t worry, this is purely cosmetic and you can rest assured that the PROS CLI will work normally. Note that opening PROS CLI.app will do nothing by design.
Windows
Sometimes, the platformio-atom-ide-terminal package fails to install properly. If this is the case, please install it manually. The method that works in most cases is to open the Command Prompt and run
In some cases when installing the PROS Editor, you may get an error message that says
Error Reading From File
. This error message should only appear a few times and you can safely click
Ignore
. You may also move the installer to a different (shorter) path, such as
C:\pros-temp
Join us on Slack!
We’ve recently set up a Slack Workspace for discussing PROS/JINX design, as well as being a more central place for PROS support. Don’t worry, we’re still going to maintain our presence on the forum, on the VTOW discord server, and on our mailing list. You can join this workspace by clicking this link.
And lastly, before you ask…
For those of you who don’t know, I’m a PROS Developer as well as the PROS Community Manager. This basically means that I’m the one online at most hours of the day, heheh
That’s because the majority of the work done on this release was completed over this past summer. And then again, it certainly still feels like it’s the summer
wav is massive why would you want to use wav anyway when you could use FLAC for same quality. Plus vex speaker is terrible anyway so its not like lossy format is gonna make a difference.
