PROS Uploading: V5 ports not recognized
My code builds/compiles fine. When I try to upload it to the cortex by running prosv5 upload or prosv5 mut in the PROS terminal, I get the following error:
ERROR - pros.cli.common:resolve_v5_port - No v5 ports were found! If you think you have a v5 plugged in, run this command again with the --debug flag
My computer is a MacBook Pro connected to the cortex with a USB-C to USB-A dongle and a USB-A to micro-USB cable. I have tried switching the dongle, the cable, and which USB port on my computer I upload from. I was able to upload from my computer to the cortex this way last year. I think we may be using a different v5 cortex this year. Anyone have any recommendations of what I could try?
To be clear, are you using a VEX V5 Brain or an ARM Cortex Microcontroller?
I would try uploading a project using VEXCode, to see if the problem is due to PROS or your computer/cable setup.
That is, if you are using the V5 Brain as opposed to the old cortex system.
Then, I would try with a different computer and different cables.
That way you can know if the problem is:
  • PROS
  • Your computer
  • The cables
  • The USB port on the brain
It might sound really strange, but see if you can find a USB 2 hub. Not 3.1 or 3.0, 2. There’s a decent chance that it might start working when using that instead of the direct C->A->micro. If you can run with the --debug flag and post that output (file upload or https://hastebin.com), that would help troubleshooting the problem hugely, too.
I’ve also had that problem, there seems to be something wrong with my port, physically.
I will work on finding a USB 2 hub. Here is the debug info:
https://hastebin.com/gelesarobu.bash
Sorry - I am using a VEX V5 Brain.
