[PROS] Using a potentiometer for setting catapult states
So I’m trying to use a potentiometer to hold the catapult in a loading state and then use a button to fire. I always want the catapult to be in a loading state unless I hit the button to fire.
Here’s the current code I have, with the potentiometer not included.
void opcontrol() {
	Controller master (E_CONTROLLER_MASTER);
	lift.set_brake_mode(E_MOTOR_BRAKE_HOLD);
	flipper.set_brake_mode(E_MOTOR_BRAKE_HOLD);
	int straight;
	int turn;
	while (true) {
		straight = master.get_analog(E_CONTROLLER_ANALOG_LEFT_Y);
		turn = master.get_analog(E_CONTROLLER_ANALOG_RIGHT_X);
		frontLeft = straight + turn;
		frontRight = straight - turn;
		backLeft = straight + turn;
		backRight = straight - turn;
		if(master.get_digital(E_CONTROLLER_DIGITAL_L1)) {
			lift = 80;
		else if(master.get_digital(E_CONTROLLER_DIGITAL_L2)) {
			lift = -80;
		else {
			lift = 10;
		if(master.get_digital(E_CONTROLLER_DIGITAL_DOWN)) {
			catapult = 127;
		else {
			catapult = 0;
		if(master.get_digital(E_CONTROLLER_DIGITAL_X)) {
			intake = 105;
		else if(master.get_digital(E_CONTROLLER_DIGITAL_B)) {
			intake = -105;
		else {
			intake = 0;
		if(master.get_digital(E_CONTROLLER_DIGITAL_R1)) {
			flipper = 80;
		else if(master.get_digital(E_CONTROLLER_DIGITAL_R2)) {
			flipper = -90;
		else {
			flipper = 10;
The idea I have circulating for the potentiometer loading is in pseudcode:
 if (launch button pressed) {
    if (potentiometer in loaded state)
        launch
    else if(potentiometer in released state)
       move to loaded state
 } else
      move/maintain loaded state
This is my quick thought on how to do it in PROS. Is there something I’m missing?
			if(loadingPot.get_value() > LOADING_STATE_MIN && loadingPot.get_value() < LOADING_STATE_MAX) {
				catapult = 127;
			} else if(loadingPot.get_value() < LOADING_STATE_MIN ) {
				catapult = 70; // Move slowly to loading state for now
		else {
			catapult = 0;
