I am currently trying to use the V5 Vision sensor in PROS C++. I used the V5 Vision Utility on a windows computer to set the first signature to something I wanted to track, and then I tried running the following code:
I assumed that 1 in the method call for get_by_sig corresponded to the first signature.
When running the code, however, the only thing that I get in the terminal is sig: 255. This happens if the object corresponding to the signature is visible or not. Is there anything that I am missing?
Thanks.
I suspect you’ll see 33, corresponding to EDOM which indicates that the vision sensor wasn’t able to find an object with that size/signature combo. You could also see 22 for EINVAL or 117 for EHOSTDOWN (which means we couldn’t communicate with the Vision Sensor for some reason).
Thanks for letting me know! I did some more troubleshooting and figured out that the problem was with the vision sensor utility not properly saving signatures.
