Who can share the contents of vscode’s “c_cpp_properties.json” file?
if i used
“compileCommands”:“ $ {workspaceFolder} /compile_commands.json”
also had problems.
It seems that its “compile_commands.json” settings are incompatible with Windows 10 1809.
I also had problems with cquery server using vsCode.
So I want to try intellisense.
This is my configuration file, but there are many problems with it.
“configurations”:
“name”: “vex”,
“includePath”:
“{workspaceFolder}/**",
"{workspaceFolder}/include”,
“c:\program files\pros\toolchain\usr\bin\…/lib/gcc/arm-none-eabi/7.2.1/…/…/…/…/arm-none-eabi/include/c++/7.2.1”,
“c:\program files\pros\toolchain\usr\bin\…/lib/gcc/arm-none-eabi/7.2.1/…/…/…/…/arm-none-eabi/include/c++/7.2.1/arm-none-eabi/thumb/v7-ar/fpv3/softfp”,
“c:\program files\pros\toolchain\usr\bin\…/lib/gcc/arm-none-eabi/7.2.1/…/…/…/…/arm-none-eabi/include/c++/7.2.1/backward”,
“c:\program files\pros\toolchain\usr\bin\…/lib/gcc/arm-none-eabi/7.2.1/include”,
“c:\program files\pros\toolchain\usr\bin\…/lib/gcc/arm-none-eabi/7.2.1/include-fixed”,
“c:\program files\pros\toolchain\usr\bin\…/lib/gcc/arm-none-eabi/7.2.1/…/…/…/…/arm-none-eabi/include”
“defines”:
“_POSIX_THREADS”,
“_UNIX98_THREAD_MUTEX_ATTRIBUTES”
“limitSymbolsToIncludedHeaders”: true,
“compilerPath”: “C:\cquery\build\LLVM-7.0.0-win64\bin\clang++.exe”,
“cStandard”: “c11”,
“cppStandard”: “c++17”,
“intelliSenseMode”: “clang-x64”
“version”: 4
