Protobot from Legacy (squarebot) Kit
I noticed that CMU software shows how to create the squarebot from the protobot kit, but is there anyone who has already figured out how to create the protobot from the legacy (squarebot) kit?
I have not compared the Parts List, but it looks looks all the parts needed by the Square Bot are in the Protobot Kit.
You can download the Inventor’s Guide, and find the necessary Parts List and Assembly Instructions for the Square Bot there…
Compleate:
VEX 2008 Inventor’s Guide Complete (27M pdf, 07-22-2008)
By Chapter:
VEX 2008 Inventor’s Guide - 1 Introduction (0.7M pdf, 06-27-08)
VEX 2008 Inventor’s Guide - 2 Structure (3.2M pdf, 06-27-08)
VEX 2008 Inventor’s Guide - 3 Motion (6.6M pdf, 06-27-08)
VEX 2008 Inventor’s Guide - 4 Power (2.1M pdf, 06-27-08)
VEX 2008 Inventor’s Guide - 5 Sensors (1.9M pdf, 06-27-08)
VEX 2008 Inventor’s Guide - 6 Control (4.1M pdf, 06-27-08)
VEX 2008 Inventor’s Guide - 7 Logic (1.9M pdf, 06-27-08)
VEX 2008 Inventor’s Guide - 8 Programming (divider) (0.1M pdf, 06-27-08)
VEX 2008 Inventor’s Guide Reference - Appendix A, Safety (0.1M pdf, 06-27-08)
VEX 2008 Inventor’s Guide Reference - Appendix B, Glossary (0.5M pdf, 06-27-08)
VEX 2008 Inventor’s Guide Reference - Appendix C, Challenges (0.4M pdf, 06-27-08)
VEX 2008 Inventor’s Guide Reference - Appendix D, Control Configurations (2.6M pdf, 06-27-08)
VEX 2008 Inventor’s Guide Reference - Appendix E, Transmitter Menus (3.1M pdf, 06-27-08)
The legacy Starter Kit is missing the following items that appear in the Protobot Kit:
1 more motor module
2 more 3" axles
4 more bearing flats
2 more 60-tooth gears
2 more medium wheels
2 more large wheels
5 more shaft collars
2 gears, 84-tooth
1 axle, 4"
2 C-Channel 1X2X1X15
1 C-Channel 1X2X1X25
Plus, less essential parts in the Protobot Kit:
50 pop rivets
3 extra clutches
nut starter
Manual, Protobot and Tumbler
I haven’t built the Protobot but visual inspection shows that the extra motor, medium wheels, 84-tooth gears, and C-Channel are needed. Most of the other parts in the first list are probably needed, too, except for the large wheels. Does anyone have a link to just the Protobot and Tumbler building instructions?
WOW!! I got that totally wrong…
“azeno” wants to Build the Protobot, with the “old” Square Bot Starter Kit.
The “old” start kit does come with the Nut Starter.
It is on the Downloads page, see VEX Quickstart Guide.
