We have created a function that handles PID turning for autonomous skills, however when it is called, the script continues to execute the next lines of code within the autonomous function without waiting for the PID turning to complete.
please post the code, that’s the only way we can help.
only thing I see is that “cprint” is not an available function for VEX Python, is that defined somewhere else ?
def turn1(expected):
expected = (expected + drivetrain_inertial.rotation(DEGREES))
wait(0.25, SECONDS)
error = expected
while True:
actual = drivetrain_inertial.rotation(DEGREES)
error = (expected - actual)
speed = (error * 0.5)
left_motor_a.set_velocity(speed,PERCENT)
left_motor_b.set_velocity(speed,PERCENT)
right_motor_a.set_velocity(-speed,PERCENT)
right_motor_b.set_velocity(-speed,PERCENT)
left_motor_a.spin(FORWARD)
left_motor_b.spin(FORWARD)
right_motor_a.spin(FORWARD)
right_motor_b.spin(FORWARD)
cprint(3,str(error))
wait(0.15,SECONDS)
if abs(error) < 2:
break
drivetrain.stop()
cprint(2,'PID Terminated')```
Called in Context of:
while rear_distance.object_distance(MM) < 1600:
drivetrain.drive(FORWARD)
drivetrain.stop()
turn1(13)```
Hi,
“cprint” is defined elsewhere; it is used to print text on the controller screen.
