currently I am using steel on my drive base and I wan to change to aluminum because the robot is too heavy so can someone tell me some weights?
1)1X5X35 steel c channel
1)1X5X35 aluminum c channel
1)1X5X25 steel c channel
1)1X5X25 aluminum c channel
1)1X2X35 steel c channel
1)1X2X25 aluminum c channel
1)1X2X25 steel c channel
Hey, Jordan.
I have your CAD library, which rocks, but I have a quick question: how do you calculate the weight of your bot once assembled, or at least, how can I find the individual weights of the parts in your collection?
May your axles remain ever straight,
Collin 1200E New Divide
Thanks!
In order to get to the weight of your part/assembly, simply right-click on the part/assembly’s name in the “Browser” on the left side of the screen. Then click “iProperties…” and in the window that pops up, click the “Physical” tab. From there, you may have to click the “Update” button to refresh the weights, but it should then give you the weight next to “Mass”.
