I am not sure how much you have accomplished with your program but here are some links to information on the Vision Sensor.
The sensor will return a value called centerY
that you can use math to determine if the robot should turn left or right.
//JPearman example
int TARGET = 150;
int error = obj.centerY - TARGET; //How far off center is the item.
// simple P control with a limit of 50
int drive = error;
if( drive > 50 ) drive = 50;
if( drive < -50 ) drive = -50;
// object is found and centered
if( obj.centerY > (TARGET-15) && obj.centerY < (TARGET+15) ) {
driveTurn(0);
else {
driveTurn( drive );
