We are finding it difficult for balls to come out from underneath the goals. We used the spacing tool to space out the goals but we are finding that the back of the goal is at the correct height but the spacing at the front of our goal is too small. Is there any way to fix this?
Make sure you have everything built right. If your still having issues, remember you have a large margin of error to still be in speck
It may be a result of the goal itself sagging (mostly apparent for the edge field goals), but if the issue is present in the corner goals as well it may be worth it to readjust them and crank down the screws to hold them in place better.
If your spacing is correct, then that’s how difficult removing balls should be.
