How many footballs can you shoot/dumb/ pickup,
8-9
Do you score the white ball,
Yes
Are you a dumper, Catapult ect, Dump
Rating of speedA: 1 is worst, 10 is best,
I would love to see a robot that could be faster than mine. But I think given the limitations of the Vex system (you can only use 10 Motors!) it is not possible to be faster maybe as fast.
2010 Awards:
Nothern Virginia (NOVA) VRC: Tournament Champion
Vex Mid-Atlantic Championship (VMAC): Tournament Finalist (Alliance Captain)
College of Southern Maryland (CSM) VRC: Tournament Champion (Alliance Captain)
Robot Questions:
How many footballs can you shoot/dumb/pickup
4 footballs or around 9 green balls
Yes
Are you a dumper, Catapult ect.
Dumper, with HS chain gears on the front to sweep balls of any size into our bucket.
Rating of speed: 1 is worst, 10 is best
(Not really sure how to put this, but you probably should have just asked what their drive motors gear ratio is, letting teams say 1-10 most would just say 10, since there isn’t much to compare to)
But anyway, my gear ratio is 1:1, not very fast, but as our team is not the richest around, we can’t afford much aluminum (just bought our first pack this year). But the pick-up system is very fast, so that balances out.
3-4 (usually 3)
yes (1 sec to pick up, another to dump ^^)
efficient, roller intake bot (similar to 254)
11/10 ^^
3:1 gear ratio
might have to chain it down to 2.5:1 though
well see
2010 Awards: 14 total, 10 qualifications to Worlds, Champion Alliance of 3 competitions, Excellence 3 times, winner of both Robot and Programming Skills challenges multiple times… A couple other ones…
Please lsist all awards
Robot Questions:
How many footballs can you shoot/dumb/ pickup: 3-4
Do you score the white ball: yes, pickup as well
Are you a dumper, Catapult ect: pick balls up, dump them over
Rating of speedA: 1 is worst, 10 is best: 7, direct-drive omni, mounted at 45 degrees
Exothermic: Team 10Q (yes we finally got a forum ID!)
Balls Dump: We can pick up 8, but reliably dump 6-7 balls in 1 second (though usually there aren’t enough balls on the field to worry about getting that many)
Green Balls: We can pick up ___ (a number too large to bother counting). We can easily score the green balls in the goals.
White Ball: We can easily store 2 white balls, as well as score them. We can also pick them up.
Type of Robot: typical roller dumper…with modifications
Speed: 2-1 Gearing with 4" omni’s → probably rates at least a 9 on this scale
2010 Awards: Lovejoy Extreme Engineering Champions
Robot Questions:
How many footballs can you shoot/dumb/ pickup 3
Do you score the white ball yes
Are you a dumper, Catapult ect Dumper
Rating of speedA: 1 is worst, 10 is best 7
