Racecar Vex-Build
Hey, I need help because my teammates and me are trying to build a racecar but we also need a good design for it since that is also a part of our grade, I don’t know which design to do since we don’t have that many parts to build with that would make the design look as good as we believe. If someone has ever built a racecar out of VEX parts I would apperite the help if you could, thanks mates*
I found a video some time ago about a race car made out of VEX Cortex, but i think you can use V5 as well, here’s the video.
What does your race car need to do?
If it just needs to be fast, then use a gear ratio of a big gear to a small gear, make your robot as streamlined as you can, e.g. make the tip pointy to “cut” through the air. Make your robot as low weight as you can.
(Also if you can add some flame drawings on the side it looks dope)
What are the constraints or rules. For example does it just have to go fast or does it have to have steering like a real car? How many motors are you allowed? Can you use 600 rpm motors?
Without info no one can help
