Hi, is there a way to work a ramp up/down code into the operator control mode code? If so, please post an example. (in easyC Pro) Thanks!
Try this, I didn’t test it but it works in my head :).
void main ( void )
int rx1;
float output = 0;
while ( 1 ) // loop forever
rx1 = GetRxInput ( 1 , 1 ) ; // get RX Data
rx1 -= 127 ; // Subtract 127 to make Neutral 0
if ( rx1 > 10 && rx1 < -10 ) // Make a deadband on the joystick
output += (float)rx1 / 100 // add .01 of joystick result to output
else // if in deadband reset output to 0
output = 0
if ( output > 127 ) // check for overrun
output = 127 ;
if ( output < -127 ) // check for underrun
output = -127 ;
SetMotor ( 1 , (int)output+127 ) ; // Write to the motors
SetMotor ( 2 , (int)output-127 ) ; // Write to the motors
Wait ( 20 ) ; // Delay Loop Time Higher will make the ramp slower/ lower will make it faster
