Hi,
Our team really needs some help quickly. The motors turn forward when pressed and backwards when pressed but won’t stop turning backwards after being pressed to go backwards. We have checked the code and everything was fine. 5 minutes ago it was working fine and then it stopped working. We have reset the core and deleted the programs and uploaded them but it still won’t work.
Please Help Urgently!!!
post code? send pics? no one can help a whole lot based off of just a paragraph
Sorry I didn’t have the code before as I am not the coder but here it is.
main.cpp
/* Module: main.cpp */
/* Author: VEX */
/* Created: Thu Sep 26 2019 */
/* Description: Competition Template */
// Robot Configuration:
// [Name] [Type] [Port(s)]
// RightMotor motor 1
// LeftMotor motor 10
// ArmMotorRight motor 2
// ArmMotorLeft motor 9
// ConveyorMotorRight motor 3
// ConveyorMotorLeft motor 8
// Controller1 controller
#include "vex.h"
#include "Autonomous.h"
using namespace vex;
competition Competition;
/* Pre-Autonomous Functions */
/* You may want to perform some actions before the competition starts. */
/* Do them in the following function. You must return from this function */
/* or the autonomous and usercontrol tasks will not be started. This */
/* function is only called once after the V5 has been powered on and */
/* not every time that the robot is disabled. */
void pre_auton(void) {
/*vexcodeInit();
RightMotor.setPosition(0, degrees);
LeftMotor.setPosition(0, degrees);
ArmMotorRight.setPosition(0, degrees);
ArmMotorLeft.setPosition(0, degrees);
ConveyorMotorRight.setPosition(0, degrees);
ConveyorMotorLeft.setPosition(0, degrees); */
/* Autonomous Task */
void autonomous (void) {
Autonomous A = Autonomous(0.05, LeftMotor, RightMotor, ArmMotorLeft, ArmMotorRight, ConveyorMotorLeft, ConveyorMotorRight);
A.arms(350);
// wait(1, seconds);
A.goForwards(0.6);
//wait(2.5, seconds);
A.intake(-30);
// wait(4, seconds);
/*A.goForwards(-0.55);
wait(5.5, seconds);
A.arms(-340);
wait(7, seconds);
A.rotation(-90);
wait(9, seconds);
A.goForwards(0.42);
wait(10, seconds);
A.intake(15);
wait(11, seconds);
A.rotation(90);
wait(13, seconds);
A.goForwards(0.6);
wait(15, seconds);
A.intake(15);
wait(16.5, seconds);
A.rotation(-70);
wait(18.5, seconds);
A.goForwards(0.25);
wait(19.5, seconds);
A.arms(340);
wait(20.5, seconds);
A.intake(-30);
//not necessary from here
wait(22, seconds);
A.arms(-340);
wait(23, seconds);
A.rotation(-90);
wait(25, seconds);
A.goForwards(0.153); // <- length of field square - robot length (24" - 18")
wait(25.5, seconds);
A.rotation(90);
wait(27.5, seconds);
wait(28, seconds);
A.intake(15);
wait(29, seconds);
A.goForwards(0.45);
wait(30, seconds);
A.rotation(90);
wait(5.5, seconds);
A.intake(15);
A.rotation(-90);
A.arms(340);
A.intake(-30); //ONLY OUTTAKE THE FIRST BALL!!1!!!!11!!1!!11
A.rotation(-90);
A.goForwards(0.45);
A.intake(15);
A.rotation(20);
A.goForwards(0.2); */
//simple auton for comp bro (general term!!!) idk
/* ConveyorMotorLeft.rotateFor(50, rotationUnits::rev, 50, velocityUnits::pct, false);
ConveyorMotorRight.rotateFor(50, rotationUnits::rev, 50, velocityUnits::pct, false); //Suck up ball
vex::task::sleep(10);
ArmMotorLeft.rotateFor(50, rotationUnits::rev, 50, velocityUnits::pct, false);
ArmMotorRight.rotateFor(50, rotationUnits::rev, 50, velocityUnits::pct, false); //Continue lifting arms to required position
RightMotor.rotateFor(950, rotationUnits::rev, 50, velocityUnits::pct, false); //Turn to the right
ConveyorMotorLeft.rotateTo(-50, rotationUnits::rev, 50, velocityUnits::pct, false);
ConveyorMotorRight.rotateTo(-50, rotationUnits::rev, 50, velocityUnits::pct, false); //Put down ball
/*task autonomous()
vex::task:sleep(100)
while(SensorValue(sonarSensor) > 20 || SensorValue(sonarSensor) == -1)
motor[robotMotor1] = -127;
motor[robotMotor2] = -127;
motor[robotMotor3] = -127;
motor[robotMotor4] = -127;
//User Control Task
void ConveyorIn (void) {
ConveyorMotorLeft.spin(directionType::fwd, 50, vex::velocityUnits::pct);
ConveyorMotorRight.spin(directionType::fwd, 50, vex::velocityUnits::pct);
void ConveyorStop (void){
ConveyorMotorLeft.stop(brakeType::hold);
ConveyorMotorRight.stop(brakeType::hold);
void ConveyorOut (void) {
ConveyorMotorLeft.spin(directionType::rev, 50, vex::velocityUnits::pct);
ConveyorMotorRight.spin(directionType::rev, 50, vex::velocityUnits::pct);
void ArmUp (void) {
ArmMotorLeft.spin(directionType::rev, 50, vex::velocityUnits::pct);
ArmMotorRight.spin(directionType::rev, 50, vex::velocityUnits::pct);
if (ArmMotorLeft.position(vex::degrees) > 70){
ArmMotorLeft = 70;
if (ArmMotorRight.position(vex::degrees) > 70){
ArmMotorRight = 70;
void ArmStop (void){
ArmMotorLeft.stop(brakeType::hold);
ArmMotorRight.stop(brakeType::hold);
void ArmDown (void) {
ArmMotorLeft.spin(directionType::fwd, 50, vex::velocityUnits::pct);
ArmMotorRight.spin(directionType::fwd, 50, vex::velocityUnits::pct);
void AbortMission (void) {
RightMotor.stop();
LeftMotor.stop();
ArmMotorRight.stop();
ArmMotorLeft.stop();
ConveyorMotorRight.stop();
ConveyorMotorLeft.stop();
//int easedown = 100;
void usercontrol(void) {
while (1) {
Controller1.ButtonR2.pressed(ArmUp);
Controller1.ButtonR1.pressed(ArmDown);
Controller1.ButtonX.pressed(ConveyorIn);
Controller1.ButtonB.pressed(ConveyorOut);
Controller1.ButtonR1.released(ArmStop);
Controller1.ButtonR2.released(ArmStop);
Controller1.ButtonX.released(ConveyorStop);
Controller1.ButtonB.released(ConveyorStop);
Controller1.ButtonA.pressed(AbortMission);
int leftPercent = (Controller1.Axis3.value() + Controller1.Axis4.value())/2;
int rightPercent = (Controller1.Axis3.value() - Controller1.Axis4.value())/2;
if (leftPercent >70){
leftPercent = 70;
if(rightPercent >70){
rightPercent = 70;
LeftMotor.spin(directionType::fwd, leftPercent, velocityUnits::pct); //(Axis3+Axis4)/2;
RightMotor.spin(directionType::fwd, rightPercent, velocityUnits::pct);//(Axis3-Axis4)/2;
task::sleep(20);
Brain.Screen.print("jbhbmngfgchk,lugj");
// prevent wasted resources.
// Main will set up the competition functions and callbacks.
int main() {
// Set up callbacks for autonomous and driver control periods
// // Run the pre-autonomous function.
pre_auton();
// Prevent main from exiting with an infinite loop.
while (true) {
/* { {RightMotor.spin(directionType::fwd, easedown, velocityUnits::rpm);
task::sleep(30);
easedown = easedown*(0.95); */
wait(100, msec);
vex.h
/* Module: vex.h */
/* Author: Vex Robotics */
/* Created: 1 Feb 2019 */
/* Description: Default header for V5 projects */
#include <math.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include "v5.h"
#include "v5_vcs.h"
#include "robot-config.h"
#define waitUntil(condition) \
do { \
wait(5, msec); \
} while (!(condition))
#define repeat(iterations) \
for (int iterator = 0; iterator < iterations; iterator++)
autonomous.cpp
#include <iostream>
using namespace std;
Autonomous::Autonomous(double r, motor &lm, motor &rm, motor&ra, motor&la, motor&lc, motor&rc) {
this->radius = r;
this->LeftMotor = &lm;
this->RightMotor = &rm;
this->ArmMotorLeft = &la;
this->ArmMotorRight = &ra;
this->ConveyorMotorLeft = &lc;
this->ConveyorMotorRight = &rc;
void Autonomous::goForwards(double howFar){
double r = this->radius;
double c = 2 *3.141592653589793238462643350288 *r;
double revolutions = howFar/c;
this->LeftMotor->rotateTo(revolutions, rotationUnits::rev, false);
this->RightMotor->rotateTo(revolutions, rotationUnits::rev, false);
cout <<"hello\n";
void Autonomous::rotation(double degrees){
double r = 0.38/2;
double distance = degrees *3.1415926 *r /180;
rhsDistance(distance);
lhsDistance(-distance);
cout << "Rotation\n";
void Autonomous::lhsDistance(double howFar){
cout << "LhS\n";
void Autonomous::rhsDistance(double howFar){
void Autonomous::arms(double degrees){
this->ArmMotorLeft->rotateTo(degrees, rotationUnits::deg, false);
this->ArmMotorRight->rotateTo(degrees, rotationUnits::deg, false);
void Autonomous::intake(double howFar){
double d = 0.048;
double revolutions = howFar *d *2;
this->ConveyorMotorLeft->rotateTo(revolutions, rotationUnits::rev, false);
this->ConveyorMotorRight->rotateTo(revolutions, rotationUnits::rev, false);
/*void Autonomous::outtake(double howFar){
double d = 0.048;
double revolutions = howFar/d;
autonomous.h
#include "vex.h"
class Autonomous {
public:
double radius;
motor *LeftMotor;
motor *RightMotor;
motor *ArmMotorLeft;
motor *ArmMotorRight;
motor *ConveyorMotorLeft;
motor *ConveyorMotorRight;
Autonomous(double r, motor &lm, motor &rm, motor &la, motor &ra, motor &lc, motor&rc);
//moves the robot forward using a provided distance (m)
void goForwards(double howFar);
//rotates the robot a given angle (deg)
void rotation(double degrees);
//moves the left wheel a given distance (m)
void lhsDistance(double howFar);
//moves the right wheel a given distance (m)
void rhsDistance(double howFar);
//Raises arms to a given degree
void arms(double degrees);
//Moves conveyors a certain distance (m)
void intake(double howFar);
robot-config.cpp
#include "vex.h"
using signature = vision::signature;
using code = vision::code;
// A global instance of brain used for printing to the V5 Brain screen
brain Brain;
// VEXcode device constructors
motor RightMotor = motor(PORT1, ratio18_1, true);
motor LeftMotor = motor(PORT10, ratio18_1, false);
motor ArmMotorRight = motor(PORT2, ratio18_1, true);
motor ArmMotorLeft = motor(PORT9, ratio18_1, false);
motor ConveyorMotorRight = motor(PORT3, ratio18_1, true);
motor ConveyorMotorLeft = motor(PORT8, ratio18_1, false);
controller Controller1 = controller(primary);
// VEXcode generated functions
// define variable for remote controller enable/disable
bool RemoteControlCodeEnabled = true;
* Used to initialize code/tasks/devices added using tools in VEXcode Pro.
* This should be called at the start of your int main function.
void vexcodeInit( void ) {
// nothing to initialize
robot-config.h
extern brain Brain;
// VEXcode devices
extern motor RightMotor;
extern motor LeftMotor;
extern motor ArmMotorRight;
extern motor ArmMotorLeft;
extern motor ConveyorMotorRight;
extern motor ConveyorMotorLeft;
extern controller Controller1;
void vexcodeInit( void );
as someone who doesn’t code a whole lot no offense but i’m not parsing through all that
can u just show the relevant bits and format it better pls lol
yea, don’t register events in a loop.
all these statements using pressed should only ever be called once.
