Re:Competition Template Bypassing Autonomous Function
You are using the same Master Code and User Code on both Vex Controllers??
So if one Controller works fine, and the other does not… That would indicate a bad Vex Controller…
Master Code being version 8 is fine for use with the Crystals.
When using Crystals, the Timers are critical in moving from Autonomous to Operator Control. Since the Timers seem “strange”, I would guess that this is the reason that the Autonomous Mode is failing…
