(Reposted from the ROBOTC Techincal Support Q&A forum)
You could try using vexRT[AccelXXmtr2], vexRT[AccelYXmtr2], or vexRT[AccelZXmtr2] to detect movement (or any value at all) from the secondary joystick to see if it’s connected.
It also appears that in the RobotCIntrinsics.c file, located in the Includes Directory, there is an Enumeration, with these Intrincs, nVexRCReceiveState, opcdSourceSystem, kSystemVEXRCReceiveState.
If you Mask OFF the top 5 Bits, the result will be:
Zero for no Controllers
One for One Controller, or
Two for Two Controllers
I don’t know without compiling some Code, if One or All Three have the same Values…
This test requires no Inputs at all, from any of the Joysticks…
#elif defined(VEX2)
typedef enum
vrNoXmiters = 0, // No transmitters connected
vrXmit1 = 0x01, // 1 == Transmitter 1 connected
vrXmit2 = 0x02, // 1 == Transmitter 2 connected
vrBit2 = 0x04, // Unused
vrCompetitionSwitch = 0x08, // 0 == No Comp Switch 1 == Competition Switch attached.
vrResetSlave = 0x10, // Unused
vrGameController = 0x20, // 0 == Legacy75MHz, 1 == Game Controller
vrAutonomousMode = 0x40, // 0 == Driver Control, 1 == Autonomous Mode
vrDisabled = 0x80, // 0 == Enabled 1 == Disabled.
} TVexReceiverState;
intrinsic const TVexReceiverState variableIndex(nVexRCReceiveState,
opcdSourceSystem, kSystemVEXRCReceiveState);
#endif
Yes, it’s very simple, just check the variable
nVexRCReceiveState
for example
if( nVexRCReceiveState & 0x01 )
// first joystick is connected
if( nVexRCReceiveState & 0x02 )
// second joystick is connected
Hmm… There is a Conflict, seen here…
Some how I don’t think Everyone is on the Same Sheet of Music…
I saw Jesse’s answer, however, I did test the variable with a partner joystick and it works as I described (under ROBOTC 3.04). You can also observe this under the system parameters debug window where the variable is also displayed.
