RE: motor runs itself
first check the trim on the controller, if that doesn’t work then you probally have a modified servo. i’ve seen some people get modified servos brand new in thier kit. check to see if it says servo module on the back, if it does then open it up to the gears and replace the black gear with one with a piece of plastic that prevents it from turning 360*. make sure you place it in the middle so you dont have it offset.
