Re: PLC troubles
By: bctc_rats
I’m assuming you are using the VEX micro controller and easyC or mplab, if not this still might fix your problem. Often I find that when operator control code isn’t working it is because whoever has written the code has forgot to put all the RC control functions in a while loop that will always be true.
Also it always is a good idea to post your tech problems on the public part of the forum in addition to the Expert part. That way you might get your problem solved sooner.
For example, not:
tank2(0,3,2,3,2,0,0)
It’s:
while(1){tank2(0,3,2,3,2,0,0)
