Re: "Sticky" Servo Button - Open half, then full
Hi tcrenshaw4bama! I’m copying your second question over to the general forum so all users (including me :)) can answer it.
I think this bit of pseudo-code might solve your problem.
It uses a integer variable (servoPos) to store the current setting of the servo. The result is that pressing the “U” button makes the servo turn backward 63 more “ticks,” and that pressing the “D” button makes the servo turn forward 63 more “ticks.”
int servoPos = 0; //Initiates servo position variable (stores current position here)
while(true) //Loop for driver control
   if((U button pressed on Ch7) && (servoPos >= -126)) //Do this if the U button is pressed, and servoPos isn't at lowest setting
         servoPos = servoPos - 63; //Decrease servoPos variable by 63
         setMotor[your servo] = servoPos; //Sets the actual servo's position to the value of servoPos
   if(D button pressed on Ch7 && (servoPos <= 126) //Do this if the D button is pressed and servoPos isn't at highest setting
         servoPos = servoPos + 63; //Increase servoPos variable by 63
Hope this helps!
