Hi: With the following code, the Angle motor will stop spinning past a position of 440 degrees only if the Controller (Axis2) is tapped >30 repeatedly. If the Controller Axis 2 is held >30 constantly, the Angle motor doesn’t stop. Seems that it doesn’t read the angle in that situation. So need a way to have the code read the Angle.position (degrees) on every loop. It is running in a task.
#include “declarations.h”
int UserContrTwo (){
while (true) {
//SHOOTER ANGLE
gShooterAngle = ShtrAngle.position (degrees) ;
if ((Angle.position (degrees) > 440) && (Angle.direction () == forward) ){
Angle.stop();
if (gShooterSide==1){ // 1 for Port 2 for Starboard
while ((Controller2.Axis2.position () > 30 ) &&
(ShtrAngle.position(degrees) < 440) ){
Angle.spin(reverse);
while ((Controller2.Axis2.position () < -30 ) && (AngleLimit.pressing() == false)){
Angle.spin(forward);
} // should close function
task::yield();
task::sleep(20);
//wait (10, msec);
return 0;
